Canon IR C2230 Advanced ( jams )
  • dustzona
    • Mar 2015
    • 83
    Have a IRC2230 that jams paper coming out of #3 cassette that then jams at the #1 tray separation assembly .Paper bumps into the bottom of that plastic piece .I changed out separation assembly and it worked better , but it still jams. Hope someone has seen this before.
  • 20 year tech
    • May 2014
    • 577
    Re: Canon IR C2230 Advanced ( jams )
    what is the jam code you are getting ?
    • roho
      • Mar 2009
      • 844
      Does it jam when using tray 4? Try running 11x17 through tray 3, if it still jams swap pick up assembly 3/4 and see if the jam code stays the same or follows the pick up assembly. If it follows the pick up assembly I would order that. If the jam remains the same you will have to do some more checking. Gotta start somewhere........
