LaserClass 730i how to set number of rings on incoming faxes?
That's a small desktop MFD yes?
Not familiar with it as it's a U.S only model but the setting SHOULD be in USER SETTINGS>RX.....or FAX SETTINGS>USER SETTINGS>RXthat's just a guess based on other MFD's I've worked on.
Sorry I can't be more helpful.
Actually it is just a older model with fax to email option. I did print out the current settings and did not see the the number of rings in any of the settings so I'm wondering if it is a Service program that needs to be changed.
Thanks for the tip though.
Delosangeles
I have this same unit as well. I have PDF copies of the manuals. I've checked the menus on the unit and I searched the manuals for "answer", "ring", "rings" and "number of" and I can tell you for sure, the manuals don't mention anything about the number of rings to answer - or how to change that number. Sorry I couldn't have been more help.
