Canon ImagePress C6000 error code
  • Laka
    • Nov 2015
    • 36
    [Error Code] Canon ImagePress C6000 error code
    Hello!
    We have a errorcode E000001-0250-05 on our C6000VP
    Presume it is the second fixing unit - but where to check ?
    Regards
    Lars
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: Canon ImagePress C6000 error code
    Inspect:
    Secondary fixing>Fixing roller main thermistor
    • aAandy
      • Apr 2012
      • 370
      Originally posted by zoraldinho
      Inspect:
      to check a thermistor electrically, put a multimeter across the two wires and you should get anywhere between 150k - 350k ohms resistance - when you hold the thermistor contact between your fingers you should see the resistance drop quickly
      if it is open circuit or the resistance doesn't change with heat - it's stuffed, replace it.
      Also if you notice physical wear on the contact surface, replace it.
      • zoraldinho
        • Mar 2008
        • 5007
        I believe that he knows how to check the thermistor. Otherwise, it's better to call an authorized Canon service for the imagepress 6000.
        • cirujano
          • Jul 2012
          • 7
          Originally posted by Laka
          Hello!
          Regards
          Lars
          1. Check for any caught harnesses. => Replace them if
          necessary.
          - fixing roller main thermistor
          - between the fixing roller main thermistor and the fixing
          external driver PCB
          - between the fixing external driver PCB and the fixing
          duplexing feed driver PCB
          - between the fixing duplexing feed driver PCB and the DC
          controller PCB 1-2
          2. Check that the fixing roller main thermistor is clean and
          properly installed. => Clean and reinstall it if necessary.
          3. Replace the following parts if necessary.
          - fixing heater driver PCB
          - fixing external driver PCB
          - fixing duplexing feed driver PCB
          - DC controller PCB 1-2
          x= 1: Primary fixing
          2: Secondary fixing
          Fixing roller main thermistor:
          THM301(primary fixing),
          THM306(secondary fixing)
          Fixing external driver PCB: UN304(primary
          fixing), UN305(secondary fixing)
          Fixing heater driver PCB: UN306(primary
          fixing), UN307(secondary fixing)
          Fixing duplexing feed driver PCB: UN311
          DC controller PCB 1-2: UN124
          • zoraldinho
            • Mar 2008
            • 5007
            I believe this problem was solved long time ago.
