IR5000 not show icon setup network
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    I have Canon IR5000(dn). I can print documents from PC by pararell port.
    I want print document from PC by network but It's not show icon for setup network in system. I change new network card already but it's not working. Please help me.
  • kwazimoto
    • Jan 2007
    • 199
    a dn sould already have a N boot rom you might want to check that also check that ps/pcl in service mode has a number beside it... if not reload system software .you might want to do that anyway the wa it sounds to me...
      • Dec 2007
      • 71
      I check try again.
      Thankyou very much.
      • satuvisiku
        i have the same problem with IR5000(s). i can browse the machine trough internet explorer (http) by entering the machine IP address and access mailbox, monitor print job etc, but i can't set it as a printer via LAN. Also when i instal scan gear, it doesn't connet to my machine with the same IP address...
        so until now i just use LPT port for printing directly from my pc
        • time2fly
          • Jul 2008
          • 134
          I have had a similar problem with a iR5000, check the the network speed setting for the nic card, if it is set to auto negotiate change to a specific speed "ie" 100mbs-10mbs. This fixed the printing and scanning issue I was having. Hope this helps.
