Canon Adv C5240 not seeing Windows 10 workgroup computers for scanning
  • kuby
    • Oct 2007
    • 1396
    Have a new customer that has a new windows 10 workgroup set up and their Canon Adv C5240 will not see the computers for scanning. Have tried to set up the machine for scanning with the SMB browser but it finds nothing. Have tried to manually input the setting and says it can not find the server. These are Windows 10 home and Windows 10 Pro computers set up on a workgroup with no Server. Had noticed that the firmware on the computer was out of date and I up graded it thinking was the problem, it did not fix it. They print to the copier just fine but wanted to scan and keep running into problems setting it up. Any help appreciated. Thanks Never run into this problem before.
  • disamm
    • Oct 2018
    • 59
    Re: Canon Adv C5240 not seeing Windows 10 workgroup computers for scanning
    iR ADV C52XX support only SMB1 with the original standard system software, it is possible that on windows 10 only smb 2 and 3 works?
    Discover SMBv1 protocol changes in Windows Server and Windows, explore alternatives for legacy compatibility, and learn best practices.
    • dan7777
      • Dec 2012
      • 680
      Something blocking it. Firewall, antivirus or something else. Sometimes we have to set up sharing permissions. Real pain as most people have no idea what is on their computer.
      • kuby
        • Oct 2007
        • 1396
        https://support.microsoft.com/en-us/...ult-in-windows
        Thanks disamm, I tried it and it did not work. Will try something else.
        • guitar9199
          • Sep 2016
          • 1100
          Go into Control Panel>Network and Sharing Center. Click the icon for the network connection (Make sure it's set to "Private" or "Work network" and not "Public") and click "Properties". Once there, click the IPv4 protocol and click the "Properties" button. Then click "Advanced>WINS Tab" and change it to "Net BIOS over TCP/IP".
          If you leave it at NetBIOS over DHCP, you won't be able to browse to the computers on the network. I had a new install a few years back after the first updates to Win 10 where I discovered this little nugget.... after 2 days!!
          You'll also likely need to go into the Windows Firewall settings, and make sure for your Inbound Rules, all instances of "File and Printer Sharing" and "Network Discovery" are set to "Enable".
          Good luck.
          • kuby
            • Oct 2007
            • 1396
            Good luck.
            Thanks I will try this..
            • MunsterTech
              • Sep 2014
              • 381
              if i recollect, I had this issue that a machine wouldnt find any network PCs or it wouldnt scan via SMB, if you go onto SIMS, some firmware now fixes the SMB scanning issue, not sure if its the browsing issue, but you can turn on SMB1 in windows, however, this is a security thing so would advise against it as can allow network attacks.
              • aAandy
                • Apr 2012
                • 370
                silly question - but are you using downloaded CANON drivers? or generic windows drivers?
                Windows 10 has some very weird properties and their generic drivers SUCK big time and cause lots of problems - this may not apply to scanning, but you never know
                i notice you updated the confuser firmware - but have you updated the machine firmware?
                also, be sure DNS server addresses are correct
                • kuby
                  • Oct 2007
                  • 1396
                  Yes I upgraded the copier firmware too.
                  • spectraindo
                    • May 2008
                    • 313
                    The problem is with Windows 10, it disables SMB1 by default so machines cannot send over SMB1.
                    If you enable it, next time Windows 10 update will kill SMB1 again, it is a real headache.
                    You can try pull scan with Color Network Scangear.
                    • aAandy
                      • Apr 2012
                      • 370
                      you didn't say if you were using downloaded canon drivers or generic windows drivers - makes a world of difference,,,, may not be your issue,, but you MUST have the basics correct
                      machine firmware, confuser firmware, and OEM drivers - not Windows crap drivers
                      • kuby
                        • Oct 2007
                        • 1396
                        Thanks kamranmunir that fixed the problem. Many Thanks.
                        • kuby
                          • Oct 2007
                          • 1396
                          This fixed the problem...
                          Go to windows control panel
                          Program and Features
                          On the left pane Click Turn Windows feature on / off
                          Find SMB client tab
                          check all on server and client option
                          apply and restart the computer.
                          your are done
