Canon iR3025 main motor runs on and off from start
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    It goes to normal warmup and ready state to make copies but the main motoris running on and off repeteadly right from start, I don't have another machine to swap boards, ah other thing is that once throwed a 733 code, (haven't done it again). The manual says that a communication error between printer board is possible, however also mentions LVPS and DC controller as possibilites, all of them very expensive items, have you run into a similar problem before'?....Customer called for a toner change only and I was very unlucky that machine started with all this once the toner was replaced...(trouble with customer).
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • teckat
    • 16083
    Re: Canon iR3025 main motor runs on and off from start
    Try cheap way
    Memory_ clean ends> reseat or replace.
    Also check outlet for proper constant supply and proper Ground to Netural +/- 0.0v > 0.5v max.
    • aAandy
      • Apr 2012
      • 370
      you may have a HVT leak at one of a hundred different places - high voltage charge leakages via arcing or toner tracks will 'wig' the machine out (spike it and confuse it)
      HVT = high voltage (charge, transfer, bias)
      LEAKAGE = high voltages shorting to ground via carbon tracking, toner buildup, or even insects dead in the wrong place
      you'd be amazed how many insects i have found fried by HVT in coronas etc, they cause the high voltage to arc to ground and 'spike' the system, causing problems
      • rapidocument
        Multibrands Tech
        • Jul 2012
        • 381
        I am going to check all that, now I have disassembled the boards and toner assy to check if mechanism its turning or not, This thing is absolutely time consuming ...(and 0 $ to get from it..!!! jeez
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          Do you still have masage"replace toner"?
          • hidius
            • Jun 2015
            • 128
            im pretty sure that noise is just the machine adding toner .. so it could just be a hopper problem. try taking the toner out and put it back in
            • rapidocument
              Multibrands Tech
              • Jul 2012
              • 381
              Yeah toner related,
              Toner pipe clogged inside.
              Strange thing didn't pop up a code though,
              Problem gone.
              Thanks to all of you guys.
