IR1730i - smearing toner
  • Benjamin98
    • Mar 2015
    • 89
    [Misc] IR1730i - smearing toner
    Hi all,
    Has anyone had this problem?
    The machine pretty much had a full service kit installed, drum, developer, transfer roller, and static eliminator. Still doing the same thing.
    The machine was being used while the toner was empty, for some time, could that have affected the developer?
    I've tested different paper as well but no luck.
    Any help would be appreciated.
    Ben0102_001.pdf
  • roho
    • Mar 2009
    • 844
    Re: IR1730i - smearing toner
    What is the condition of the fuser?
    • Benjamin98
      • Mar 2015
      • 89
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5019
        I'm not sure where is the problem exactly. Loose lines?
        • Benjamin98
          • Mar 2015
          • 89
          That may not have been a good example: see the attached
          0103_001.pdf
          The toner is smudging - image is not clear
          • zoraldinho
            • Mar 2008
            • 5019
            Environment? (wet,hot,cold) ?
            Non oem toner?
            • ldharnden
              • Apr 2011
              • 47
              Have you tried replacing the whole transfer feed assembly (FM4-6520-000)? Another easy something to try, on the static eliminator/guide. Wrap a bit of electrical tape over the far side contact and reinstall. Does the problem go away?
              • MunsterTech
                • Sep 2014
                • 381
                replace the transfer rolller and static eliminator, there is a bulletin on SIMS about it
                • Benjamin98
                  • Mar 2015
                  • 89
                  I've replaced the whole transfer assembly with a known working one but still no joy.
                  Really tearing my hair out trying to discover what's wrong with this machine!
                  • Benjamin98
                    • Mar 2015
                    • 89
                    Hi Idharnden,
                    I have tried replacing the whole transfer assembly. I also did try the electrical tape on the static eliminator but didn't change anything unfortuntely
                    • Benjamin98
                      • Mar 2015
                      • 89
                      Hi all,
                      Please can someone tell me what would cause a background on a printout. Surely something is not being discharged correctly?0114_001.pdf
                      • Andyboachie
                        • 185
                        Originally posted by Benjamin98
                        Hi all,
                        Please can someone tell me what would cause a background on a printout. Surely something is not being discharged correctly?[ATTACH]41038[/ATTACH]
                        Hi,
                        Let's try this: Spread some few copy sheets in a sunshine and ensure it is totally moist free. Use the sheets immediately for copy and see if there is an improvement. If there is, the problem might be cause by moisture.
                        If no positive result, try interchanging the HVT with a known working one.
                        • Benjamin98
                          • Mar 2015
                          • 89
                          Originally posted by Andyboachie
                          Hi,
                          Hi Andy,
                          I have done what you suggested with the paper but no change at all - so I guess it's not a moisture issue.
                          I have also replaced the transfer roller and static eliminator but nothing either. I've changed the HVT previously as well
