Canon IR8070 Error 004---0001
  • abkonnet
    • Mar 2008
    • 166
    IR 8070 Shows Error 004 subcode 001 and the machine heater lamp does not turn on properly some times it turn on some time it is not..
  • teckat
    • 16083
    Re: Canon IR8070 Error 004---0001
    Short Circuit
    SSR
    Did u check wall outlet voltages, especially Netural to Ground=0.0v>0.5v max
    • abkonnet
      • Mar 2008
      • 166
      Originally posted by teckat
      Short Circuit
      SSR
      neutral to ground is 2.8 volt
      • abkonnet
        • Mar 2008
        • 166
        When the error appears and i turn on the machine the machine starts normally... but the heating lamp is not turning ON
        • abkonnet
          • Mar 2008
          • 166
          Problem solved there is a dry solder in relay RL1 in AC Driver pcb which doesn't give proper power .
