iR 6565i problem
  • darkocg88
    • Jan 2018
    • 63
    iR 6565i problem
    Greets,
    I have a problem with iR 6565i, barely visible print.
    Ive replaced all 3 coronas, ITB cleaner, problem remains the same.
    Ive also replaced the toner unit from a working machine, problem remained the same.
    Checked the developer unit, its rotating properly, so not the issue as well.
    Thanks in advance for any help.
    Image of print in attachment.
  • dan7777
    • Dec 2012
    • 680
    Re: iR 6565i problem
    Originally posted by darkocg88
    Greets,
    Turn off potential control, turn bias down as far as 150. My company uses generic toner but we have had new copiers with canon toner be light on set up. I was concerned this would not hold up copy quality with potential control turned off but surprisingly all my machines run fine with this setting. I use test chart #2 to check if it is dark enough. You want to be able to see the bars at the top.
    • darkocg88
      • Jan 2018
      • 63
      Since first post somehow doesnt have attachment, this is how print looks like.
      • dan7777
        • Dec 2012
        • 680
        That is the developer. A stirring rod breaks. They have a new style rod but I put in a new developer with the -020 at the end.
        • darkocg88
          • Jan 2018
          • 63
          Actually it was HV pcb but thanks alot for help. Cheers.
          Sent from my Moto E (4) Plus using Tapatalk
