CANON IR3300
  • princepriyu
    • Mar 2025
    CANON IR3300
    hi all
    i am facing an issue
    its an error E602-0002
    Canon IR 3300
    What should i do to solve this problem
  • Brian8506
    • 1655
    • princepriyu
      Re: CANON IR3300
      please can any1 guide me to install firmware of 3300
      on an new hard drive
      i'm having SST and software
      and parallel port cable to connect computer LPT port with copier
      or how to use it with network
      thanks in anticipation
      • princepriyu
        Re: CANON IR3300
        i am getting following error
        pls chk image
        which option should i select
        i am using NEW 40 GB Hard Drive
        • kuby
          • Oct 2007
          • 1362
          Re: CANON IR3300
          Are you using a hard drive that is compatible with the copier, not just any hard drive will work? There are steps to follow in order when connecting to the computer and the copier and starting the System Software.
          Do you have the Upgrading Procedure for this machine?
          • ahmad
            • Jun 2010
            • 28
            Re: CANON IR3300
            you have to change original canon hard desk and then to connect the parallel cable and go to download mode
