help.. ir3225 e000716-0010
  • balad
    • Jun 2014
    • 16
    [Error Code] help.. ir3225 e000716-0010
    ir3225 e000716-0010
  • petermays
    • Mar 2017
    • 91
    Re: help.. ir3225 e000716-0010
    hi
    the error is a communication error.remove the 3 way unit and make sure plugs and cabling are ok.can also be a dc issue.
    • balad
      • Jun 2014
      • 16
      Originally posted by petermays
      hithe error is a communication error.remove the 3 way unit and make sure plugs and cabling are ok.can also be a dc issue.
      thank you for the answer, 3 ways is that the cable finisher huh? sorry I use translators because I don't really understand English!
      • balad
        • Jun 2014
        • 16
        the machine is still error e000716-00010, I have tried replacing the dc controller and checking the cable I think there is nothing to break, I have to check what are you friends? Thank you in advance
