IR Adv c2225 jam code 105
  • laro
    • Dec 2011
    • 18
    Hi Guys, IR adv c2225 keeps jamming on all trays including bypass and gives jam code 105. Code indicates reg sensor. Can anyone suggest the best way forward. I am not too familiar with machine. Is there a way to test operation of sensor quickly. Thanks in advance.
  • JPiek
    • Oct 2014
    • 435
    Re: IR Adv c2225 jam code 105
    Reg sensor is PS20,open right door, open patch sensor :
    Clean reg sensor:
    Johan
    • laro
      • Dec 2011
      • 18
      Thanks for responding JPIEK. Cleaned reg sensor but that did not solve the problem. Help!! Anymore suggestions are welcomed.
      • dan7777
        • Dec 2012
        • 680
        I had to replace that sensor once for jamming there. It is hard to find as it comes on an assembly. I got the part number from someone who had same issue off the canon website. That was two years ago. I used the manual instructions to put it in.
        • JPiek
          • Oct 2014
          • 435
          Part you're looking for is FM3-8117-020
          See attachment for installation...
          Johan
          • laro
            • Dec 2011
            • 18
            Thanks for responding guys. Will check it out and respond. Will definitely state what the fix was once i get it right.
            • laro
              • Dec 2011
              • 18
              I changed the registration assembly unit ( FM3 8117 020) and all is well now. Special thanks to Jpiek and dan7777 for their assistance.
              • jcarrascom
                Thanks Men...
                • dan7777
                  • Dec 2012
                  • 680
                  I think he was correct. I had to replace one. Hard to find part but he showed it. A little bit of a pain. If you have manual follow instructions.
