CANON LBP 6310dn
  • Polo-022
    • Sep 2007
    • 484
    CANON LBP 6310dn
    Hi,
    I have a problem with an LBP 6310dn.
    The vertical center of the paper do not fuses properly, but the sides from center to left and right are fixed and looks OK.
    I changed the fixing film, pressure roller, pr. roll bushings, heat element, but it not helped.
    Also tried to change the toner.
    It works great when i choose heavy paper from printer settings..
    Please, have you got suggestions what could be wrong?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: CANON LBP 6310dn
    Compatible Or oem toner?
    • Polo-022
      • Sep 2007
      • 484
      Compatible.
        Originally posted by Polo-022
        Compatible.
        there is the problem.
        • Polo-022
          • Sep 2007
          • 484
          Thanks,
          I can't say so, because there is another printer LBP 6310 in the
          same office which works with the same toner without a problem...
          can it be the fusing film quality, i put an HP P2055 compatible...
          • roho
            • Mar 2009
            • 844
            Thanks,
            I trust "compatible" fixing films less then I trust "compatible" toner. Can you switch fusers? See if the problem follows the fuser.
