Hi
I need help with this it only stretches image one way in the paper feed direction the image size is perfect its the other way the image is stretched. I have tried a different laser assy but stays the same checked the laser adj settings and they are ok . see attached samples
Thanks for any help
20181129082439.pdf
The reports print the same way and ltr-r is stretched see attachment20181129085635.pdf
Thanks for any help
20181129082439.pdf
