IR3300 Copier- Error E00602-001 After Assembling
  • Andyboachie
    • 185
    Hello,
    I was working on an IR3300 copier with a working HDD. The paper was jamming on the clutch just adjacent to the pickup roller for the bypass tray. When I checked, the clutch was stuck. So i worked and restored it. Before I removed the clutch, I removed the HDD mistakenly in order to get access to the screws on the PCB unit. But after I assembled, I now see an E000602-001 error. As i said the HDD was working fine before I unset the machine. Is there anything I should be doing? Kindly suggest options. Thanks in advance!
    Re: IR3300 Copier- Error E00602-001 After Assembling
    Originally posted by Andyboachie
    Hello,
    was the machine powered on at the time?
    • Andyboachie
      • 185
      No, it was not powered on. Because I was trying to remove the the clutch adjacent to the bypass pickup roller, I even needed to remove the power board. So the first thing I removed was the power cord.
      After the error, I have tried to replace the cable that connects the HDD to the PCB, but no result.
