canon iR-ADV 4525 imageRUNNER ADVANCE
  • gogi100
    • Jul 2011
    • 18
    [Misc] canon iR-ADV 4525 imageRUNNER ADVANCE
    i have this device. i configured option for sending mail from this device, but i don't know how configure that this device sends report counter? the device notify me when out of paper or toner empty. thanks
  • disamm
    • Oct 2018
    • 59
    Re: canon iR-ADV 4525 imageRUNNER ADVANCE
    So far i know, is this not possible. On the RUI (Remote User Interface - Webpage) you can configure only --> Toner, Waste Toner and Paper Jam.
    • gogi100
      • Jul 2011
      • 18
      some other solution for my request?
      • RobertOB
        • Dec 2018
        • 26
        DCA Software that polls through SNMP and can notify with certain conditions? Like a Linux VM running Observium maybe?
        • DFM914
          • Jun 2010
          • 73
          From the web page, login as Administrator. Choose Settings/Registration then in the left side column, choose Device Management under Management Settings. Select E-mail Notifications Settings. From here you can create what type of notification you want to send (No Toner, Waste Toner or Paper Jam)
          • petermays
            • Mar 2017
            • 91
            hi
            as i understand you cant get meter readings sent to you.we get toner low..paper jam..error codes but cant get meter readings.we either have to call client or get in our car and go get ourselfs
            due to IT restrictions on what is allowed to run through .
            • disamm
              • Oct 2018
              • 59
              the other possibility would be to install iwemc (Need a Microsoft System), then the meter capture plugin. Configure this plugin to retrieve the meter readings at certain intervals. No mail with counter readings will be generated, but csv export will be done, which can then be sent by mail.
              to much for only one device.
