Canon IR 1730 Scan Density adjustment
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    I know Im not the brightest star in sky.I also know that if I was starting out today as a copier
    repairman,Id be in big trouble and be looking for another line of work.Thankfully after 40 years in this bussiness,
    I live a simple life and do not need a lot to survive,Am I the only one is cannot understand or figure out what
    even a simple adjustment is when needed from the Canon IR 1730 service manual.
    The machine scans lite and copies lite.Does anyone know how to increase density on this machine in scan mode and method
    for knowing that the machine is properly toned up(another issue on this machine unrelated to scan issue,
    Im going nuts trying to figure this out from the manual.
    THANKS FOR ANY HELP AND BEING PATIENT FOR MY SHORTCOMINGS
    Andy
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon IR 1730 Scan Density adjustment
    Registering the Standard Send Settings
    Follow this procedure to change and register the standard send settings.(see PDF)
    Manuals for iR1750i/1740i/1730i
