iR-ADV 8205 image distortion
  • QC91
    • Oct 2016
    • 91
    [Misc] iR-ADV 8205 image distortion
    we have an 8205 keeps dumping excess toner with marks on the pages, we have cleaned and replaced a broken patch sensor, we also replace addition parts but the toner marks come back after 2000 pages, I have listed all the parts we changed, I will attach a photo any help would be appreciated
    FM3-7298-010 PATCH SENSOR ASS'Y / IR-ADV 8085/8095/8105/8205/8285/8505 SER UL
    Canon FM4-5429-020 (FM4-5429-010) Developing Assembly
    Canon FM3-7291-010 (FM3-7291-000) Drum Unit Holder Assembly
  • Canuck
    Tech Specialist
    • 1713
    Re: iR-ADV 8205 image distortion
    Make sure the small gear at rear of drum unit(AP kit)when turned causes the mag roll and auger to turn in the drum cleaner assembly. I have had the auger break so it doesn't move the waste to the cleaner drive assembly. I replace the cleaner assembly on the process unit(its fun...lol)
    • QC91
      • Oct 2016
      • 91
      Hi, Canuck thank you for the help we noticed that one of the gears was frozen in Waste Toner Feed Assembly we lubricate it, but after 5000 pages the toner mark came back, the auger in AP kit is working, we don't see that much toner in the waste bottle would you recommend replacing M4-0899-010 Waste Toner Feed Assembly ? or anything else I should check thanks again
      • roho
        • Mar 2009
        • 844
        Replace the ap kit as a assembly. I have had this as well, and the gears may turn individually when somewhat disassembled, assuming that's what you did to lube it. Lube won't work, order the entire assembly including the sep assembly and swap out the drum to the new one.
        • Canuck
          Tech Specialist
          • 1713
          The waste drive is usually not the issue..if it backs up, you will get an E13 error. Usually the problem is in the cleaner assembly itself. As Roho suggested,replace the AP kit(drum holder assembly)... it comes with the cleaner assembly attached to it.Make sure you order the right one...6000 and 8000 are different. I have replaced quite a few waste drive assemblies also(Fm4-0899). They are notorious for backing up. I have quite a few 8000s/8200/8500 running 125k per month on each and this is common on them
          • QC91
            • Oct 2016
            • 91
            Thank you, everyone, we just installed FM4-0899-020 and everything is working I also found this post Ir Adv 8105 breaks spiral coil every 2 weeks
