No by pass select screen irc 5051
  • pontiac
    • 420
    Insert any size paper and the screen only displays displays[ adj guides] never switches to by pass options screen. Thanks for results
    Re: No by pass select screen irc 5051
    so what have you done? sounds like sensors in BP tray not registering properly
    • pontiac
      • 420
      Phil thanks for reply We swapped the whole rt door unit. We did not find any bypass adjustments in service manual. Thanks
      • guitar9199
        • Sep 2016
        • 1100
        Service Mode>Copier>Function>CST, and look under the MF (Multi-Feed) settings adjustments. A4R, A6R, A4, Once you set all of those, the "adjust side guide" message should go away.
        • Canuck
          Tech Specialist
          • 1713
          Is something registered in User Mode for the bypass? Make sure there is not. If user settings are ok, you might want to do some RAM clears. Make sure to back them up in service mode first.
