Ir 3300 language problem
  • eng_migo
    • Jun 2008
    • 16
    i have a machine ir 3300 i want change its language to english i got sst and the ir3300 firmware but each time i tried to change the language i got an error message "error145"
    note : the cable i use wrote on it "IEEE 1842 centronics standard cable "
    plz anyone can help me ?
  • welshman
    Technical Support Manager
    • Oct 2007
    • 91
    you need to copy the boot rom as well
    change to uk under body options
    • Raoufselwaness
      Expert
      • Nov 2008
      • 75
      that what i have in my manual for 2200/2800/3300
      CHAPTER 5 SERVICE MODE
      Page 5-10 T
      COPIER>DISPLAY>USER
      <USER>
      Indicates items related to the User screen and the user.
      LANGUAGE
      Indicates the language/paper size configuration used.
      Indication <LANGUAGE xxyy.zz.aa>
      Where,
      xx (higher 2 characters): country code (See JIS.)
      yy (lower 2 chargers): language code (See ISO639.)
      zz: destination code (00: Canon, 01: OEM,
      02: common (all))
      aa: paper size configuration code (00: AB, 01:
      Inch, 02: A, 03: all sizes)
      if u could solve your problem pls com again and tell us
      • Raoufselwaness
        Expert
        • Nov 2008
        • 75
        COPIER>DISPLAY>USER
        Page 5-10 T
        LANGUAGE
        Where,
        02: common (all))
        MODEL
        Indicates the model (0: iR2200, 1: iR2800, 2: iR3300).
        PLS if have solved your problem com again and tell us
        • eng_migo
          • Jun 2008
          • 16
          each time i tried to download boot , system , language or format
          the program gives me error 145
          • eng_migo
            • Jun 2008
            • 16
            COPIER>DISPLAY>USER
            Page 5-10 T
            LANGUAGE
            Where,
            02: common (all))
            MODEL
            thx for ur effort but i think i need to change software of the machine coz it doesn't contain english language
            • costd
              • Jan 2008
              • 409
              I believe error 145 is Timeout has occurred because of a communication failure.
              Is it possible you are not using a laptop with a parallel port for the centronics cable? If you are using a USB to Parallel - that is a no-go unless the cable is a NetHawk.
              • eng_migo
                • Jun 2008
                • 16
                i am using a desktop computer with parallel port and a centronics cable
                but it give me error 145 also
                • kuby
                  • Oct 2007
                  • 1405
                  Have you followed the upgrade procedures...You have to do it step by step.
                  Start your computer, start the SST, connect the parallel cable to the copier, plug in the copier, press and hold 2+8 and turn on the copier until the Down load mode it displayed.
                  • bnmand
                    • Sep 2008
                    • 383
                    I think you mean IEEE1284. You need to have ECP mode enabled for your computer's parallel port. This can be changed in the BIOS (usually by pressing F10 when booting and/or in the device settings in Windows.
                    Edit: I guess your problem was not using download mode on the copier, but not using ECP mode on the computer is a number possible problem for some users.
                    • hari_4848
                      • Jul 2008
                      • 91
                      You need to enable the ECP mode in your computer in the BIOS settings.
                      This can take care of your problem .
                      If u dono much about the ECP mode , try using a cross cable(Ethernet cable) and communicate with the Ip address in the SST.
