Canon IRC3080 tray 1 multifeeding
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Not real knowledgeable on this machine but I have one that is multifeeding from tray 1. From just looking at it I saw the sep roller seats up with a torque limiter(which has been replaced but did not resolve issue) and that would be the cause of it. Sep Roller looks good and when you close side door it is engaging the sep roller up against the feed roller. Is there more to this system or is it just basically shaft, torque limiter, and sep roller or am I missing something? I don't have a parts manual to look at a diagram.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
  • teckat
    • 16083
    Re: Canon IRC3080 tray 1 multifeeding
    Parts Catalog > Canon > iRC3080 > page 24
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      Originally posted by teckat
      Was actually the next page is actually what I was looking for but this is definitely the start I needed. Thanks a ton teckat!
      • teckat
        • 16083
        Have not seen this model in a long time,
        but remember pick up roller needs to release, think u can swap no.1 with no.2 pick up units to check
        • guitar9199
          • Sep 2016
          • 1100
          I THINK 2, 3 and 4 can be swapped...but IF I remember correctly, Cassette 1 PFU is its own creature. You'd have to switch out some of the hardware on it for it to work in 2 or otherwise.
          ...like you, it's been a while since I've seen one...but that kind of jumps out in my mind.
          • teckat
            • 16083
            Yeah, u are right, different animal
            #1=
            #2,3,4=
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              I'm a Kyocera and Konica Minolta tech but we inherited this machine at a school district so this is a new beast to me. Seems there isn't much to the system I have just never seen it before so was wondering if it might be common issue. Thanks for the help and info tho.
              • teckat
                • 16083
                The paper inside the cassette is held up by the lifter plate. When pickup takes place, the pickup roller moves down to come into contact with the surface of paper.
                The pickup roller is moved down when the pickup solenoid goes on.-----------If it does not move back up (off) it will grab next sheet and move paper to pickup before first sheet trail edge passes sensor
                The feed roller and the separation roller serve to make sure that a single sheet of paper is moved to the feed path, and the paper is moved as far as the registration
                roller by the work of the vertical path roller.
                The pickup vertical path roller, pickup roller, feed roller, and separation roller are driven by the cassette pickup motor.
                The STOP PLATE on solenoid may be sticking---preventing it's release.
                SL2: Cassette 1 pickup solenoid
                Before Removing Cassette Pickup Solenoid
                1) Detach the rear right cover.
                2) Detach the right cover.
                3) Detach the right lower cover.
                4) Remove the cassette pickup unit 2.
                5) Remove the cassette pickup unit 1.
                Delay Jam for the Pickup Unit
                The leading edge of paper does not reach the sensor after the cassette 1/2 pickup motor has started to rotate.
                Cassette 1 ------cassette 1 pickup motor (M4) cassette 1 ------- retry sensor (PS25)
                • Kidaver
                  Ghoulscout
                  • Apr 2011
                  • 912
                  Now this makes sense and I will be sure to check this and report back. Should have known...old machine...solenoid feed system...sticky pad...
