White dots on solid prints.
  • tinnyjay
    • Oct 2009
    • 663
    Hi
    I am having white dots on solid prints (could be on text also but can't verify).
    Machine is a IR8105 and developer unit is new one, transfer belt(film) is also new.
    Could be drum? Drum heater is on.
    Any idea?
    Thank you
    "Who loves the roses,must also bear thumbs"
    Re: White dots on solid prints.
    Originally posted by tinnyjay
    Hi
    Any idea?
    Thank you
    you said 'film' is new... did you clean the rollers below the belt/film? they can build up crap on them and cause spots..
    could also be the drum or even paper.
    and pics of the problem?
    • Brian8506
      • 1664
      Did you rewire the coronas?
      Sent from my iPad using Tapatalk
      • tinnyjay
        • Oct 2009
        • 663
        Yes, i cleaned them.
        • tinnyjay
          • Oct 2009
          • 663
          Primary corona is new also, the other no.
          • Brian8506
            • 1664
            You have to rewire them
              wonder how many techs bother doing the process proper anymore? I got quite good at restringing Canon corona's
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5009
                I hate coronas. Especially when I lose spring on a gray carpet.
                  yup ..sucks worse than a 2bit ho!
                  I used curved hemostats to hold spring while stringing that end.
                  • zoraldinho
                    • Mar 2008
                    • 5009
                    Hemostat!? Good idea!
                    And for other side? Hex key?
