IRC 5185
  • kirwayne
    • Sep 2008
    • 30
    IRC 5185
    IRC 5185 Error Code E202-0101 help please if you can
    Thank you
  • BLITZKREAGG
    irc 5185
    Product : imageRUNNER C5185 / C5185i Title : E202-0101 and E202-0102 error codes displayed on the Color imageRUNNERs C5185 / C5185i Error :
    Workaround :
    E202 error code with the two new subcodes 0101 and 0102 pertain to the new Contact Image Sensor (CIS Unit) used in the DADF-T1 for the two-sided simultaneous reading DF. The following describes the two subcodes:
    E202-0101: Backside reading glass (CIS) Home Position error. The Home Position cannot be detected in the detection (outward) of the Home Position of the backside reading glass (CIS).
    E202-0102: Backside reading glass (CIS) Home Position error. The Home Position cannot be detected in the detection (homeward) of the Home Position of the backside reading glass (CIS).
    The CIS Unit resides in the DADF-T1
    Note:
    Please see the attached Technical Publication
    TP07 193b.pdf for further information.
    • BLITZKREAGG
      irc 5185
      Product : Color imageRUNNER C5185 / C5185i / C4580 v2 / C4580i v2 / C4080 v2 / C4080i v2 Title : E202 - 0101 Error :
      E202 - 0101 is indicated at power on.
      The HP cannot be detected in the detection (outward) of the HP position of the backside reading glass (CIS).
      The DADF controller drives M6 when necessary and moves the CIS glass. By executing such procedure, the DADF controller compares reflection data of the standard white plate position with that of the image scanning position, and executes the correction of shading and dirt detection.
      Workaround :
      PLEASE READ ATTACHED TECHNICAL PUBLICATION (TP08-013) FIRST!
      Verify the operation of M6 and PI13 and replace parts consequently.
      [1] Check M6 in PART CHECK> MTR-CHK> 5 for operation and verify the connection of J214 on ADF Driver PCB (PCB7).
      [2] Check for PI13 sensor state in service mode FEEDER>I/O > P006 - 6 (0:HP) and verify the connection of J412 on ADF Controller PCB (PCB1).
      PI13 - CIS glass moving HP Sensor WG8-5593-000
      M6 - CIS glass moving motor FK2-3715-000
      PCB1 - ADF controller PCB FM3-0369-000
      NOTE: Before you replacing the ADF Controller PCB (PCB1), print a P_PRINT and see the description given under "After Replacing the ADF Controller PCB" on the host machine service manual.
      i hope this helps let me know
      • kirwayne
        • Sep 2008
        • 30
        Thank you
        Thank you very once again you guys have got me out of a sticky situation
        thank you
