IR3025 jam code 0B00
  • campy
    • May 2012
    • 315
    I have a IR3025 that is throwing an 0B00 door open jam code at least a couple of times when making 50 copies. I have changed the door switch but that didn't fix it. Anyone have this problem on any IR series?
    Re: IR3025 jam code 0B00
    did you check for broken door latches?
    • campy
      • May 2012
      • 315
      The latches are fine. It did it even when I had my knee against it to make sure it wasn't popping out a little.
      • Brian8506
        • 1664
        It might be the sensor for the Toner door. Make some copies and open that door while the machine is in motion and see if you get that code
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5007
          Check lower right door.
          Check grounding plate on registration roller ( bent or dirty).
          • dan7777
            • Dec 2012
            • 680
            from canon
            Error :
            The jam code 0B00 is not listed in the service manual and indicates that the right door has been
            opened while the machine is making a copy. The most common causes are door and lower right
            door related.
            Workaround :
            There is a remote signal that runs through the HVT that shuts off power to the HVT if the door is
            opened, if the signal is lost during copying the jam code 0B00 is the symptom.
            In this particular case the HVT FM2-0261-000 was the cause of the jam.
            Make sure the metal leaf spring on the registration rollers is making good contact. I bend it and apply conductive grease. Can cause all kinds of weird issues.
