IR3245 Fax
  • Brian8506
    • 1664
    IR3245 Fax
    Customer has a fax and a 2nd/3rd line kit installed. Only line 1 is used. Fax only works with on hook. When using line 1 there's no dial tone and fax goes right into re-dial. No attempt to dial number. If I plug the fax line into line 2 or 3, copier sounds like it's dialing but no dial tone and no transmission. Customer does have a DID phone system with an analog card that I assume is supposed to supply an analog line for the fax but I don't know enough about telephone systems to be sure. I have removed 2nd/3rd kit and changed line 1 kit but no change. Any thoughts? Maybe not compatible with the phone system?
  • mosey1100
    • Mar 2009
    • 143
    Re: IR3245 Fax
    These machines only work with a dedicated phone line, not on phone systems.
    • Brian8506
      • 1664
      Re: IR3245 Fax
      It does work but only with the on hook button
      • techandtrader
        • Jun 2016
        • 330
        Re: IR3245 Fax
        I would run a CLEAR ALL on the fax and update the firmware. After that get another board. Running a credit card machine off the Phone port is another WRONG move. workx or not its NOT supported.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
        • Brian8506
          • 1664
          • mosey1100
            • Mar 2009
            • 143
            Re: IR3245 Fax
            You could check if " Check Dial Tone Before Sending" is turned on under Additional Functions > Communication Settings > Tx Settings > Fax Settings. Make sure it is OFF.
            • Brian8506
              • 1664
              • Brian8506
                • 1664
                • Brian8506
                  • 1664
                  Re: IR3245 Fax
                  I think it has to do with the DID system they use.
