Canon IRA C2225 Light Image on Copies/Prints
  • doug
    • Dec 2011
    • 198
    Hi Guys,
    Once again another light print issue on this model machine...
    Tried:
    replacing transfer roller
    all drum life indicators were under 100 on all four drums.
    I was just at this customer yesterday and they sent the following sample print (it was making beautiful copies/prints yesterday)
    Any ideas?
    Thanking all of you in advance,
    Re: Canon IRA C2225 Light Image on Copies/Prints
    Originally posted by doug
    Hi Guys,
    Tried:
    Any ideas?
    Doug[ATTACH=CONFIG]41657[/ATTACH]
    well.. life on parts?
    was the unit cleaned?
    all other PM parts replaced and init'd on time and properly?
    bias values on devs - drums - transfer?
    made sure contacts on T Roller clean?
    • JPiek
      • Oct 2014
      • 435
      On all colors or just black ? Lifecount under 100 for drums doesn't say it all on these models, specialy so for the Bk drum..
      can you do a PG5 on each color ? What does it look like ?
      Johan
      • doug
        • Dec 2011
        • 198
        Im kind of new on these models...could you please tell me how to do a PG5 and PG6 test in service mode?
        Thank you so much,
        Doug
        • doug
          • Dec 2011
          • 198
          And it seems like it is only on the black (see sample)
          Thank you,
          Doug
          • dan7777
            • Dec 2012
            • 680
            Hi Guys,
            Tried:
            Any ideas?
            I have replaced plenty of drums with less than 80% on this model but they are mostly dark. To clean the laser glass with out taking it out you have to go into the service mode and open the shutters and then use the cleaning tool on the front door. It is not too hard to take the laser out on the left side. Going just by the sample and the black drum is good I would say laser glass is dirty.
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5015
              I would put a laser isue first.
              Second,this will be a developer issue more then a drum.
              To locate a color issue print PG-10 test.
