ImageCLASS MF9220C ALL Cartridges not recognized
  • CCC Repair
    • Sep 2014
    • 47
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4978
    Re: ImageCLASS MF9220C ALL Cartridges not recognized
    Hi
    There is no click on this model. If cartridge not in the place you can closed the door.
    OEM Canon cartridges??
    Practice makes perfect
    If you want something done right, you have to do it yourself
    • CCC Repair
      • Sep 2014
      • 47
      Originally posted by zoraldinho
      Hi
      • zoraldinho
        • Mar 2008
        • 4978
        I would start with the connectors on the dc controller.Re-seat them all.
        Clear-all sometimes surprisingly helps. Do not do this without manual.
        • apoxi
          • Nov 2015
          • 45
          Change this plastic-down below is broken
          Code: RC1-6643-030
          • CCC Repair
            • Sep 2014
            • 47
            Thanks I will look at that
            • CCC Repair
              • Sep 2014
              • 47
              Code: RC1-6643-030
              • CCC Repair
                • Sep 2014
                • 47
                Code: RC1-6643-030
                I went out to the machine and could not find where that part was so I’m wondering if it broke completely off. Are there two of them or just one? I wasn’t sure if there was one on each side? And also when I went to order the part they said it was in the paper feed mechanism. And that can’t be right
