Poor Image for Printing(Canon ADV 8205)
  • lianexay
    • Aug 2016
    • 25
    Dear Sir All Here
    Seek for your all help. My Canon ADV 8205 Poor Image when printing, Just Image is not good Quality. Printing text is okay, Photocopy is Okay for Image and Text,
    kindly have a look in attached.
    thanks in advanced.
  • lianexay
    • Aug 2016
    • 25
    Re: Poor Image for Printing(Canon ADV 8205)
    Hi, all kindly helping me on this.
    thanks very muach
    • Canuck
      Tech Specialist
      • 1713
      Do all images print this way? Is it a color image printed greyscale? Test prints from engine ok? Need more info
      • lianexay
        • Aug 2016
        • 25
        thanks for reply me and help me. kind have a look my answer and question below.
        1. yes all image printed on this way.
        2. this color Image printed in greyscale(machine is can printed black and white)
        3. how do I printed test image from machine?
        • dan7777
          • Dec 2012
          • 680
          thanks very muach
          I could not tell if it was light or what issue the machine was having from the picture. We turn potential control off and lower developer bias to darken copies. My company gives generic toner but even with canon toner we are getting new copiers that are light. Some techs adjust corona height for darkening copies.
          • lianexay
            • Aug 2016
            • 25
            thanks for replying, but i still can not fix this issue, could you suggestion me another ways for fix this.
              • 22808
              " Seek for your all help. My Canon ADV 8205 Poor Image when printing, Just Image is not good Quality. Printing text is okay, Photocopy is Okay for Image and Text,"
              Please explain " Poor Image when printing, Photocopy is Okay for Image"
              Are you printing a SCANNED image? (what DPI and how does the scan look when VIEWED?)
              A file? what is DPI (resolution) set for in the file?
              you REALLY give us little to work with...
              remember we are NOT on site..
              maybe post the config pages to give us an idea HOW the machine is setup for: SCAN - PRINT file/image/PHOTO
              • lianexay
                • Aug 2016
                • 25
                Thank you very muck reply me, kindly see my explanation in each you question.
                - got the same result from scanned image and take a picture image.
                - any file type Jpeg, png
                do you mean this configuration ?
                • davel
                  • Oct 2011
                  • 1045
                  Sounds like you are not servicing properly if you are adjusting dev bias and corona height.
                    • 22808
                    [ATTACH=CONFIG]41779[/ATTACH]
                    NO PRINTED config sheets
                    " Are you printing a SCANNED image? (what DPI and how does the scan look when VIEWED?)
                    ok dude we have ASKED so certain info.. YOU ALWAYS LEAVE OUT PART
                    WHATS THE FUCKING -=DPI=- SET AT FOR SCANS?
                    WHEN YOU PREVIEW -=BEFORE PRINTING=- WHAT DO THE FUCKING SCANNED FILES LOOK LIKE? LIKE THE FUCKING PRINT OR CORRECT...
                    THIS IS LIKE PULLING FUCKING TEETH WITH YOUR ASS... DONE
                    READ my post to NEWBIES -----> READ THIS
                    • dan7777
                      • Dec 2012
                      • 680
                      Ok, on a brand new machine with light copies what would you suggest? An advance 6575?
                      • roho
                        • Mar 2009
                        • 844
                        This series has always been light out of the box. Adjusting corona height sounds like a good idea to me.
                        • lianexay
                          • Aug 2016
                          • 25
                          I Apologize for my poor in English.
                          i have make a list of Result between make a photocopy, print out and configure before scanned to computer In the link below . kindly have a look my explanation.
                          anyway Thank so muck for try to helping.
                          Binder2.pdf - Google Drive
                          • dan7777
                            • Dec 2012
                            • 680
                            Thanks. That guy telling me I was not servicing it correctly was something else. He obviously has not worked in the field much.
                            • dan7777
                              • Dec 2012
                              • 680
                              That to me looks like a problem from your computer. I would try canon ufr2 print driver, and try scanning to pdf instead of jpg. I have not gone back to all the posts to see if you updated your software on copier. If what I saw the scan made it to your computer and looked close to scanned original, then you should get a black and white original a lot better than you did. Sometimes you have to try different things. You could try scanning to your mailbox and print from there to see the difference.
