C5051 Time for a Dev Unit? Missing yellow stripe
  • techandtrader
    • Jun 2016
    • 335
    Removed and checked the dev unit. It is updated and rotates good. Replaced and ran 10 more test pages. No further problems observed. I have never seen a Dev Unit pause like this if the gear is updated and solid. Suspect motor glitch... yellow shift.jpg
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • dan7777
    • Dec 2012
    • 680
    Re: C5051 Time for a Dev Unit? Missing yellow stripe
    Originally posted by techandtrader
    Removed and checked the dev unit. It is updated and rotates good. Replaced and ran 10 more test pages. No further problems observed. I have never seen a Dev Unit pause like this if the gear is updated and solid. Suspect motor glitch... [ATTACH=CONFIG]41723[/ATTACH]
    That is strange. Make sure the x shaped coupler on rear of developer is new white style not black. Run auto color mismatch and it should fail. Clean the itb sensors. Seems like I have seen that before and it all had to do with finding what caused auto color mismatch to fail.
    • techandtrader
      • Jun 2016
      • 335
      Couplers are A OK. I have replaced and updated many. Yes, it's very strange.
      • mc007
        reliable tech
        • Jan 2019
        • 28
        if you please ,post pg5 (with yellow only)
