Canon IR ADV 8105 Error 001-002 when print B5
  • Kyaw Thu Ko
    • Jun 2018
    • 10
    [Error Code] Canon IR ADV 8105 Error 001-002 when print B5
    Dear ALL,
    I would like to request your help for my Canon IR ADV 8105.
    When I print A4 size paper from my Canon 8105, the printer is fine. (no error)
    But when I print B5/A4R/Legal size paper, the thermistor error E001-002 come out.
    Please help me to solve that problem.
    Thanks in advance
    Kyaw Thu Ko
  • mc007
    reliable tech
    • Jan 2019
    • 28
    Re: Canon IR ADV 8105 Error 001-002 when print B5
    Originally posted by Kyaw Thu Ko
    Dear ALL,
    Thanks in advance
    Kyaw Thu Ko
    what about the heat roller ? is it OEM ? make sure its genuine heat roller or not .
    • Kyaw Thu Ko
      • Jun 2018
      • 10
      Dear
      heat roller is OEM.
      But Upper Fuser Roller is Compatible New.
      • mc007
        reliable tech
        • Jan 2019
        • 28
        Dear
        heat roller is OEM.
        replace upper fuser roller with OEM roller and check.
        • Kyaw Thu Ko
          • Jun 2018
          • 10
          The problem is I cannot buy OEM parts in my country.
          • Kinesis510
            • 13
            hello Kyaw Thu Ko
            Had this same problem 2 years ago when I bought my first ir 8105 you need a OEM upper fuser to work properly, compatible upper fuser will not work, what i did is buy used OEM upper fuser roller and had a company Re Teflon coat the used upper fuser rollers, suggestion buy OEM lower fuser roller if it wears out,
            compatible parts will not last long.
            good luck
