Canon iR ADV C5051 - E0027-400
  • luis1984bol
    • Nov 2011
    • 148
    [Error Code] Canon iR ADV C5051 - E0027-400
    Regards,
    I had a problem with a Canon iR ADV C5051, the error E0027-004 is displayed almost every day. The user has to restart the machine every time.
    I had replaced the Developing Bk unit, but after a week the error is back.
    Do you have any idea about this problem?
  • techandtrader
    • Jun 2016
    • 330
    Re: Canon iR ADV C5051 - E0027-400
    E027-0400 AdvC5035
    Canon IRC5030
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
    • teckat
      • 16083
      Originally Posted by canonbundy
      View Post
      Hi, I've been away for a while however the fix for E027-0X00 (providing dev couplings etc are ok) is to remove the Hopper seals on not only the offending colour but the other 3 also, as they in turn will error E027-0X00.
      The ADV5051 series are getting old, and as a result so too are the seals & with the pulling out/in of the Process Unit to clean/replace Drum units, the Hopper seals for the Developer Units lose their grip & over a period of time slide forward each time the Process Drawer is drawn forward until the Seal actually blocks/covers the Toner dispensing hole, which in turn deprives the Developer Unit of Toner resulting in the Error.
      Remove the Process Unit, ITB Assembly & Fusing Unit (for easy access) with a good torch you will see the Seal of the offending Hopper hanging down & with a small pair of pliers grip the seal & with a backwards/forwards movement of the Toner dispensing Tube slowly (without breaking the Seal) pull the Seal towards the front of the machine - believe it or not, the Hopper does not leak excess toner & no other adjustment/settings need to be made, vacout the machine, clean Patch Detect Sensor assy & perform full Autograd.
      Cost - about half an hour.
      Cliff.
      • luis1984bol
        • Nov 2011
        • 148
        View Post
        Cliff.
        Thank you. I am going to try that.
