ir adv 4051 paper jam
  • cesarkazu
    • Jun 2012
    • 28
    [Jamming] ir adv 4051 paper jam
    hi friends.
    I have Canon Ir adv 4051 and jam in inner finisher D1 paper output, happens when you take a reasonable amount, for example 1 or 2 copy does not jam, 5 copies or more jams crashes,
    only on A4 size paper. Letter,A4R not jam and A4 two side does not frequently jammed.
    Waiting for some help
    • 22808
    Re: ir adv 4051 paper jam
    Originally posted by cesarkazu
    hi friends.I have Canon Ir adv 4051 and jam in inner finisher D1 paper output, happens when you take a reasonable amount, for example 1 or 2 copy does not jam, 5 copies or more jams crashes, only on A4 size paper. Letter,A4R not jam and A4 two side does not frequently jammed.Waiting for some help Thanks
    [ATTACH=CONFIG]41755[/ATTACH][ATTACH=CONFIG]41756[/ATTACH]
    well what have you tried?
    what does your service manual say could be the issue
    what are the life counts on parts?
    • cesarkazu
      • Jun 2012
      • 28
      hi,
      -fix film is new but not original
      -roll fusion is new but not original
      -cassete pickup rolls is new and original
      -paper is heated in 40C best quality 75g/m2
      -all rolls is clean
      in service manual did not find anything about it
      by the photo looking the paper like it just folds the right side
      inner finisher D1 is disassembled and cleaned
      thanks
      • cesarkazu
        • Jun 2012
        • 28
        solved, it was broken at least it stopped jamming, 29- FE2-1648-000 SPRING, LEAF0205_001.pdf,
