IR ADV 8095-8295
  • viczulis
    • Apr 2012
    • 52
    [Misc] IR ADV 8095-8295
    Is there a FUSER QA KIT from canon for these machines? Part # ?
  • Iradfo01
    • 20
    Re: IR ADV 8095-8295
    Hi,
    haven't found a kit available i use canon parts below.
    FC5-2286 WEB
    FL3-3602 UFR
    FM4-3158 LFR UNIT (INC BEARINGS)
    FC9-8067 BUSHING SPACER
    FM1-C081-010 UFR BUSHES (x2)
    FE2-0550 UFR BUSHING SPACER
    XG9-0563 UFR BEARINGS (x2)
    • viczulis
      • Apr 2012
      • 52
      Originally posted by Iradfo01
      Hi,
      FC5-2286 WEB
      FL3-3602 UFR
      Thanks. Do you also have part # for the fuser separate claws
      • Iradfo01
        • 20
        No Problem
        FB5-3625-000 X6 Sep claw
        • ronbo4114
          • 6
          no i always replace the ufr,lfr,both bushings and the clip. i use the modification ring that is used on the 6000 series on the rear side after pulliing off the plastic wire guides, i just leave them hanging and space the clip screw that holds the heating element in. if you dont it will hit the new mod. i got tired of the rings coming off after i rebuilt one one in every 3 no more problem with that
