Tiger strips with C800
  • khattab.al.masry
    • 212
    Dears all:
    good morning we face problem with our Canon imagepress C800 suddenly tiger strips appear as shown in the following file attached
    the actions was taken as in the following sequences:
    1-replace black developing assembly------------few days and the image fault came again
    2-replace primary H.V connector assembly------also few days and the image fault came again
    3-replace grid and wire for corona assembly----------also few days and the image fault came again
    as seeing in the attached file the problem is related only to color black.
    thanks in advance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    Re: Tiger strips with C800
    It's looks like some kind of vibration like bad drum gear... Not familiar with this model.
    There may be a bulletin if anyone can check..
    • ronbo4114
      • 6
      it looks like an issue with the itb assy. a transfer issue.
      • ronbo4114
        • 6
        i see small white spots on the second test page. looks like pinholes in the itb belt. they will be black on the belt itself i have had this a few times.
          Originally posted by khattab.al.masry
          Dears all:
          thanks in advance.
          What is the page count on drum K and Tbelt? Is that defect only one egde only? (more than likely the SIDE L/R not T/B of page)
          looks kinda like a drum issue.
          sounds like you wasted Time/Parts before knowing the cause.
          • hutmah
            • Sep 2017
            • 18
            Can you see that pattern on the dev cylinder? If not i would do a forced stop to check the drum,belt and so on and see where the issue is visible for the first time
            • khattab.al.masry
              • 212
              .[/QUOTE]
              We had taken this action as the last procedure and waiting the result.
              Thank you.
              Sent from my SM-J700H using Tapatalk
                Thank you.
                did it fix it?
                Sent from my SM-J700H using Tapatalk[/QUOTE]
                • nicknt82
                  • Nov 2011
                  • 154
                  Dears all:
                  thanks in advance.
                  Take out cover of Develop Unit. If you can see tiger strips on Cylinder, that maybe hopper can't supply enough toner. Than take out hopper unit and check
                  • khattab.al.masry
                    • 212
                    Thank you for your input
                    Yes we see tiger strips on developer unit cylinder.
                    But till now after replacing drum it is working good if issue is repeated again our next step is replacing black hopper according your advice
                    • khattab.al.masry
                      • 212
                      did it fix it?
                      yes it fix it case is closed
                      thank you.
                      Thank you.
                      [/QUOTE]
