Any thoughts out there. don't work on these small canon printers. Maybe somebody does.
Canon MF734 cdw E078-000
Re: Canon MF734 cdw E078-000
E078-0000 - Primary transfer disengagement mechanism error.
The primary transfer roller didn't engage or disengage when it was suppose to, might need Engine Controller PCB, Primary Transfer Disengagement Solenoid, Primary Disengagement Switch, or check the wiring coming from Engine Controller PCB.Comment
Thank you once again. Just can not get the firmware in UK/Europe updated Dec 18 you suggested, the latest version on the Canon dealer site here is V0305 (MAY 18). There is a later version on the USA canon public site you attached to your last thread but only July 18. Not sure where to go now to get the Dec update that as you say will fix the problem. any ideas my friend.Comment
