ir6570 lost results
  • balad
    • Jun 2014
    • 16
    ir6570 lost results
    hello friends from all over the country, sorry to ask, ir6570 the results are gone by themselves and I clear dc-cnt is normal again but after my machine restarts the results are gone again and if the po-cnt = 0 the results are not lost just clear. what I have done is replace all corona wire, replace HVT, DC control. but the result is no change. help the solution. sorry if the words are not understood because I use google translator, I am not good at English, thank you.
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: ir6570 lost results
    Which results are you talking about?Do you mean the machine makes blank copies on default po-cnt=1?
    If so,then the HVT pcb could be faulty or the charger blocks could be having leakages and need replacement.
    • balad
      • Jun 2014
      • 16
      Originally posted by COPIERTEC ASSOCIATES
      Which results are you talking about?Do you mean the machine makes blank copies on default po-cnt=1?If so,then the HVT pcb could be faulty or the charger blocks could be having leakages and need replacement.
      thank you for your response, friend, yes if po-cnt = 1 for a number of sheets the results are good but if the engine is turned off then it will be empty. the results appear again after clear DC-CON
        • Aug 2011
        • 279
        Unseat the BootRom and RAM and clean and fix back on the printer pcb,if it fails to keep memory replace the Lithium battery on the Printer pcb.
        The last option is to change the HVT pcb.
        • balad
          • Jun 2014
          • 16
          Unseat the BootRom and RAM and clean and fix back on the printer pcb,if it fails to keep memory replace the Lithium battery on the Printer pcb.The last option is to change the HVT pcb.
          I'm ready to try, thanks for the advice of friends
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5005
            Did you try to enter data from the door?
