Canon IR4570 How to get this part.
  • Picaflor
    • Mar 2019
    • 3
    Good afternoon I have a question about a Canon IR4570 which you have fallen these pieces that end or burned or breaking after a while and there is no way to repair them I searched the internet but I can not find the complete part and less the rodos anyone knows how that part is called or if there is a 3d model to print them.
    Thank you.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon IR4570 How to get this part.
    Does device have a built-in internal finisher?
    • CS0523
      • Feb 2015
      • 35
      the left picture is from the paper delivery assy.
      number 12, 13, 14
      and the right picture show the number 5 from the paper delivery assy.
      paper.pdf
      • Picaflor
        • Mar 2019
        • 3
        If you have an A1 finisher.
        number 12, 13, 14
        [ATTACH]41943[/ATTACH]
        Correct those are the pieces you know where I can find your replacement or if there is some way to print them in 3D.
        • techandtrader
          • Jun 2016
          • 335
          If its high meter 500k or more ....The 3225 I think are the same parts. Also the C3080 use the same part. If not you can try a drop of oil to make them quiet again. The last time I checked, the C3480 parts will work in the 3235 series.
          The white part is what wears down the most. I think both parts are Disc at Canon.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • Picaflor
            • Mar 2019
            • 3
            The parts are broken and there is no way to repair them.
            I was asking for 3D printing because I thought it was funny a few years ago I saw a photo of a photocopier in this forum and some parts of the 3 way unite were black, not like the normal ones that are gray.
            Holder Roller FC6-2915-000
            Delivery Collar Unit FF6-0345-000
