Canon IR 2520 paper jam and error showing E000110
  • hafiz
    • Mar 2019
    • 10
    [Error Code] Canon IR 2520 paper jam and error showing E000110
    Dear all,
    Please help me to solve the problem described here.Paper come in front of drum unit and paper jam occurs.When i removed the jammed paper and close the door it shows E000110 error.(Canon IR 2520).Also noted that no image is coming on the drum.I replaced the drum unit and laser unit and also factory reset,but the error repeats.kindly help.Thanks in advance
  • Andyboachie
    • 185
    Re: Canon IR 2520 paper jam and error showing E000110
    Originally posted by hafiz
    Dear all,
    Hello,
    Carefully observe the behavior of the scanner as you try the copy. A malfunction with the laser scanner unit can cause a jam. The fact that no copy appears can also enforce this suspicion. Check if the motor is working well, of if there is any obstruction in the movement of the scanner. Check the scanner cable and its connection as well. It could help if you have another machine to try swapping a working scanner unit, the cable and even the DC Controller board if all else fail.
    • hafiz
      • Mar 2019
      • 10
      Originally posted by Andyboachie
      Hello,
      dear thanks for reply.
      i swapped the laser scanner unit with working machine but same error and also this laser unit is working fine in other machine . now cable connectors and dc controller board is remaining but i dont have idea of dc controller board and main board . if i replace the dc controller board ,any issue of firmware . i am little hesitate about this.
        he said check the SCANNER when making copies.... i have seen it do it on other brands also
        • hafiz
          • Mar 2019
          • 10
          dear , i have checked the laser scanner unit properly. the laser scanner unit is working fine in other machine. when i disconnect the laser scanner unit and start the machine , showing same error on screen E000110 but when connect the wires of scanner and start . then occur paper jam and showing same error on screen . it means wires of laser scanner unit or dc controller board issue.
            You are still confusing me on your use of scanner..laser scanner working fine in other machine.
            Are you talking ROS..
            or scanner on top with paper feed to make copy.
            I am talking about scanning bed on TOP
            • Andyboachie
              • 185
              Hello Hafiz,
              It is good you have another machine for checking! Now swap the cables and finally the DC board. Hoping you get a solution buddy!
              • hafiz
                • Mar 2019
                • 10
                dear . i have checked and swapped laser scanner unit which is (internal and beside drum and developer unit ) now i will check scanner bed on top. also will test through print from pc. thanks for telling me this point.
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5007
                  Sometimes the door switch can cause E110
                  • dan7777
                    • Dec 2012
                    • 680
                    Looks like from the manual E110 is the laser scanner you swapped. If you were working around main controller check J8142 and make sure it is seated right. Canon knowledge base mentioned a switch by drum and a shutter cable to laser scanner. Paper stops at registration roller.
                    E110 0002 Title Failure of the Scanner Motor (M21)
                    Description The speed lock signal indicates a deviation 10 times in
                    sequence at intervals of 100 msec after the signal has
                    indicated a locked state.
                    * The same condition is detected after the error retry is
                    performed.
                    Remedy 1.Check the cable.
                    2.Replace the Laser Scanner Unit.
                    3.Replace the DC Controller PCB (PCB4).
                    E110 0003 Title Failure of the Scanner Motor (M21)
                    Description The scanner motor (M21) speed lock signal does not indicate
                    a locked state for 6.5 sec. after a switchover is made from
                    low to normal speed or for 8 sec. after a switchover is made
                    from normal to low speed.
                    performed.
                    • dan7777
                      • Dec 2012
                      • 680
                      The manual mentioned on the dc controller board you should do a backup and restore. Could have firmware issues with main board but does not talk about main board being an issue. I update with usb and this stupid machine makes you do a toner stir after update and I have never had any issues fixed with a software update so I never do it. If you were working on machine you could go back over everything. The picture of the cable and switch showed a white plastic and spring with switch by end of drum with door open. It is good you do not just swap main boards without checking what you need to do.
                      • hafiz
                        • Mar 2019
                        • 10
                        Thanks to all ..
                        machine issue has been resolved. i just opened the machine back covers and scanners cable jack in main board and dc controller board j208,j8142 and j8143, unplug and plug . now it is working fine , no paper jam and no error . thanks again to all those who helped me .
