boot update
  • digitaltech006
    • Jun 2025
    boot update
    I have a ir 4570, replaced harddrive and installe sst on pc, got it download via swith and rj45, but two the files are not loading one is ir2270_system_USenv3603 with error E261 (needs Boot Version :0636 or later) other one is Time Limit ir-XXxx0201-710E-Brows.dat only loads to 48% (E211). Where can i get updated files. Got Software CD from Canon.
  • kuby
    • Oct 2007
    • 1395
    How old is that CD...My MN-CONT is 39.01, BootRom 11.43_N. Do you have a Service Manual for it machine. You have to follow the Upgrade Step by Step, or you will have errors everytime.
    • digitaltech006
      boot update
      never mind i found out that harddrive was also bad started to lock.
      i installed a new one and every thing went smoothly, also used a cross over cable. thanks
      • pbakker
        CD 4570
        Kuby,
        I was reading your reply, I am having problems with the CD. Do you know where I can get the CD? We are not a Canon dealer but I have one hear with Hard Disk problems.
        Thanks!
