E805 code
  • CopyDawg
    • Dec 2008
    • 74
    E805 code
    I have a Cannon 330S thats throwing an E805 code. Anybody know what this is? Any help would be much appreciated. Thanks
  • Oze
    Ricoh Fanboy
    • 1663
    If your subcode is 0007 you need to replace 3 fans...FM4,FM7 and FM8 at the same time.
    That subcode says that fuse FU200 on the DC pcb has blown so you'll need to replace that fuse prior to fitting the fans.
    If your subcode is 0002 it means that fuse FU201 is an open circuit and either has to have a new fuse soldered in or replace the DC pcb.
