Have two machines as mentioned in the same location doing exact same thing. It only happens on longer runs and symptoms identical. Feeding into finisher, It starts making a "popping sound". It will get louder and then start nicking the lead edge of the paper (11" LEF) towards the operator side about a third of the way back. Eventually, it will jam with code 1011-01 and be rolling up in the finisher entrance guides. Cannot see where it is nicking or where the noise comes from. I suspect the way it behaves in long runs only, it is a clutch heating up and overdriving for a popping noise and maybe a gate catching causing the nick? Looking for the voice of experience here. Sure appreciate and advice.
Canon IR 3225 and 3235 both jamming J1011-01
Re: Canon IR 3225 and 3235 both jamming J1011-01
Hello,Have two machines as mentioned in the same location doing exact same thing. It only happens on longer runs and symptoms identical. Feeding into finisher, It starts making a "popping sound". It will get louder and then start nicking the lead edge of the paper (11" LEF) towards the operator side about a third of the way back. Eventually, it will jam with code 1011-01 and be rolling up in the finisher entrance guides. Cannot see where it is nicking or where the noise comes from. I suspect the way it behaves in long runs only, it is a clutch heating up and overdriving for a popping noise and maybe a gate catching causing the nick? Looking for the voice of experience here. Sure appreciate and advice.
You did not indicate that you checked the code from its manual. If you say "longer runs", how long does it run before the symptoms occur? You did not indicate what efforts you have put up in trying to solve it. You can take cover from location of the clutch or any other suspected area and do visual inspection? -
Probably after 50 pages, it will start the noise. Then it progresses over the next maybe 20 prints. Took the top off of the finisher and looked for obvious. Jam is not making the fusing entrance sensor which makes you feel it happens prior to finisher. Noise sounds like from finisher but hard to tell.Comment
To be sure, could you detach the finisher for the machine to stand alone during copying? That will let you know if the problem is coming from the fuser exit. It will make it easier for you to trace. The jam code indicates the copy does not enter the finisher on time, causing the finisher inlet sensor to record an error.Probably after 50 pages, it will start the noise. Then it progresses over the next maybe 20 prints. Took the top off of the finisher and looked for obvious. Jam is not making the fusing entrance sensor which makes you feel it happens prior to finisher. Noise sounds like from finisher but hard to tell.
If everything is working fine, then your next option is to inspect the rollers, gears, and clutches when the noise is coming. The noise is surely coming because a revolution is being obstructed.Comment
Let's see if the cause is peculiar with the machine or maybe there might be a remote cause of that fault.Comment
You should remove all the damper pads for all the sensor flags and the gates on the door. These can cause jams when they get old and sticky. Especially the registration flag.
Sent from my iPhone using TapatalkComment
Thanks, both machines are in an accountant's office so unless they get real bad, my time to tear into them will be limited before tax time ends April 15th. I am just trying to get a good train of thought to be prepared. Thanks for all suggestions.Comment
Understood. I actually thought about the pads and did check them for sticking. The problem is opposite what my experience with sticking pads was. They used to jam after sitting awhile but once they broke free, seemed to work until they got a chance to stick again. Still, very good info and it is on my list to check. Removing the finisher will be a bit more time involved. It is almost like it runs awhile, something starts to "jump time", and nicks the pages, and shortly after that, it is enough to create the jam. I just can't believe that two machines in two different rooms but maybe 15-20 feet apart came up with the exact same oddball problem at the exact same time. strange huh?
Is it strange? Or does that indicate customer has caused this issue, check for something out of place that a customer may do removing a jam, that seems much more likely then a coincidence?Understood. I actually thought about the pads and did check them for sticking. The problem is opposite what my experience with sticking pads was. They used to jam after sitting awhile but once they broke free, seemed to work until they got a chance to stick again. Still, very good info and it is on my list to check. Removing the finisher will be a bit more time involved. It is almost like it runs awhile, something starts to "jump time", and nicks the pages, and shortly after that, it is enough to create the jam. I just can't believe that two machines in two different rooms but maybe 15-20 feet apart came up with the exact same oddball problem at the exact same time. strange huh?
Customer has a healthy fear of the machines. They will call me to install toner. I don't mind. I tried putting a spacer under the spring loaded upper guide on finisher entrance where it starts it's "rolling" on the more troubled machine. Will see if it changes anything but that doesn't really explain the noise unless it is coming from delayed finisher entrance...I thought and don't believe I will be able to remove finisher as I think there are exit flags and sensors that are removed when finisher is installed. I don't have old flags to put on it to run without the finisher. Will keep you posted on results and appreciate the suggestions.Comment
