Error 0003-0002
  • HELIO240
    • Jan 2011
    • 137
    [Error Code] Error 0003-0002
    Hi ! I Have a canon c700 printer that show error cod E0003-0002 .I changed heat sensor THM1 and cables on it.In the service mode in copier>display >analog Temperature on FIX-LC is varing from 42 degrees until 92 degrees when printing at service however the Fx-LE keeps stable in 100 degrees. This error happens intermittently ,I would like to know if anyone has already got this problem and how was the solution . Thanks in advanced.
