Canon IR C5030 Fax to Email
  • Shtroumf
    • Mar 2019
    • 10
    Hi,
    It's probably something really simple but i cant seems to find it in the options, i have this printer that forward all incoming fax to an email adress (Forward w/o Condition) perfectly like we want but it print the fax also, i only want the fax to be receive by email
    Thank you
    Jonathan
  • nicknt82
    • Nov 2011
    • 153
    Re: Canon IR C5030 Fax to Email
    Printing Documents to be Forwarded
    If you want to check the documents to be forwarded for yourself, you can set the machine to print the documents whenever they are forwarded, or to print only the documents that failed to be forwarded.
    <Menu> <Function Settings> <Receive/Forward> <Fax Settings> <Forwarding Settings> <Print Images> Select <On> or <Only When Error Occurs>
    • Shtroumf
      • Mar 2019
      • 10
      i can go to <Fax Settings> I dont have the option <Forwarding Settings> its weird
