Canon Iradv 4235 dead Copier
  • RAFO
    • Mar 2018
    • 6
    Ir advance 4235 when powered on , no display ,no motors, only power on Led and energy saver Green Led on. Any clue?
    Re: Canon Iradv 4235 dead Copier
    take it out of energy saving mode?
    how many pages on it?
    what has been done to it?
    did you have a power surge/problem?
    do you have SM for the machine?
    are you a tech?
    you haven't given us anything to diagnose with
    • RAFO
      • Mar 2018
      • 6
        Well most common probably is the HDD..
        • Bchabot
          • Jan 2017
          • 4
          Could also be dead screen.
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            If the screen is dead, the machine is still set to ready. You hear the motors. He does not hear them.
            • zoraldinho
              • Mar 2008
              • 5007
              Advice?
              Boot System Error Diagnosis Tool --------Turn ON the Main Power Supply Switch while pressing the Control Panel Power SupplySwitch.
              This tool automatically checks the Control Panel, Main Controller PCB 1, All-night PowerSupply, and Non-all-night Power Supply, and notifies the result by the number of light-out andblinking interval of the lamp on the Control Panel.This tool is installed in the ROM of Main Controller PCB 1.
              Controller System Error Diagnosis Tool----------Turn ON the Main Power Supply Switch while pressing the numeric keys '2' and '4'simultaneously.
              This tool automatically checks the Main Controller PCB 1/2, child PCBs mounted on the MainController PCB 1/2, and HDD, and display the result on the Control Panel.This tool is installed in HDD.Therefore, this tool cannot be used when an error occurred in HDD or HDD cannot beaccessed.
              • RAFO
                • Mar 2018
                • 6
                Thanks for the info. Will keep posted on this problem.
                • Bchabot
                  • Jan 2017
                  • 4
                  Ahh, missed the "no motors" part. My bad.
