initialization failure
  • silimi
    • May 2025
    [Error Code] initialization failure
    good day to all.i am having this problem and am stuck.its just saying Checking data... do not turn OFF the main power.What is the solution.Canon C3325i
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5002
    Re: initialization failure
    What is the solution? To find a part that causes problems ofcourse.
    Boot System Error Diagnosis Tool --------Turn ON the Main Power Supply Switch while pressing the Control Panel Power SupplySwitch.
    This tool automatically checks the Control Panel, Main Controller PCB 1, All-night PowerSupply, and Non-all-night Power Supply, and notifies the result by the number of light-out andblinking interval of the lamp on the Control Panel.This tool is installed in the ROM of Main Controller PCB 1.
    Controller System Error Diagnosis Tool----------Turn ON the Main Power Supply Switch while pressing the numeric keys '2' and '4'simultaneously.
    This tool automatically checks the Main Controller PCB 1/2, child PCBs mounted on the MainController PCB 1/2, and HDD, and display the result on the Control Panel.This tool is installed in HDD.Therefore, this tool cannot be used when an error occurred in HDD or HDD cannot beaccessed.
    • alex@wocltd.com
      • 430
      do a backless overwrite all f/w update
      • jimmurphy
        • Oct 2020
        • 5
        Hi,
        I have the same problem. What was the solution?
        Thanks!
        • julka123
          • Oct 2009
          • 36
          Originally posted by jimmurphy
          Hi,
          Thanks!
          Hi,
          Replace 1. Flash disk , 2. HDD
          • jimmurphy
            • Oct 2020
            • 5
            Your talking about an optional flash disk?
            Where are there instructions for this and/or hd replacement?
            I was reading this unit came with a 250 gb drive...
            Does the hard drive need to be preformatted in any way?
            Originally posted by julka123
            Hi,
            • julka123
              • Oct 2009
              • 36
              The flash disk is a small PCB for the mn controller, you can order it only from Canon, then install the system.
              • jimmurphy
                • Oct 2020
                • 5
                So, to get to the hard drive, its behind the PCB board I was told.
                How much is the Flash Disk roughly ?
                For the hard drive, doe sit have to be formatted in a certain way?
                • julka123
                  • Oct 2009
                  • 36
                  ~100 USD
                  • jimmurphy
                    • Oct 2020
                    • 5
                    Thanks for responding.
                    Could you give me some more details about what's involved changing the hard drive and/or flash drive?
                    Does the hard drive have to be preformatted a certain way like exfat or does the copier format the hard drive?
                    ~100 USD
                    • jimmurphy
                      • Oct 2020
                      • 5
                      Canon says try flashing firmware...
                      O.K. where could we get that and what is the process?
