Canon iR Advance c5240 black blur copy
  • brianho80
    • Sep 2009
    • 198
    Hi guys,
    at the beginning after finding b/w blur print out, i perform the following steps trying to solve the problem.
    1) at first i change a drum ( took from other unit) -> remain blur
    2) replace another black bottle toner-> remain blur
    3) replace dv tank ( took from other unit) -> Ok
    but after existing K toner bottle finish, and replace with new one, it start blur again.
    anyone encounter this issue before?
    appreciate if you could share with me if you have similar problem.
    Re: Canon iR Advance c5240 black blur copy
    Originally posted by brianho80
    Hi guys, at the beginning after finding b/w blur print out, i perform the following steps trying to solve the problem.
    but after existing K toner bottle finish, and replace with new one, it start blur again. anyone encounter this issue before?
    wow you noobs don't give us shit for information...
    PAGE COUNTS total and on service parts.
    OEM or compat toner?
    did you CLEAN the machine?
    stop test to see whats causing blur?
    what does the fuser look like? warps cuts..?
    • mc007
      reliable tech
      • Jan 2019
      • 28
      please post a complaint copy
      • dan7777
        • Dec 2012
        • 680
        Hi guys,
        That sounds like it is the toner. I have heard stories of people filling oem bottles with waste toner or toner from a printer. Start with a new developer, new oem bottle. Vacuum the toner hopper. That is if you are saying the developer "tank" is the developer next to the drum.
        • brianho80
          • Sep 2009
          • 198
          • bineeshgeorge
            • Jul 2009
            • 107
            Chance of humidity
            Sent from my X41 Plus using Tapatalk
            • Canuck
              Tech Specialist
              • 1713
              Machine meter, dev count and sample print
              • smiley
                • Aug 2008
                • 616
                i face this problem before check the hopper of black color at the back. maybe there are some clog toner on it.
                there is no glory without sacrifice
