canon ir 2870
  • justo66
    • Apr 2019
    • 6
    [Misc] canon ir 2870
    Hello I have a canon ir 2870. There is full ink in the development tray, but the machine displays insert ink cartridge and stops it.
    Help me please
    Re: canon ir 2870
    what "development tray"? Post pics of this
    [/QUOTE] but the machine displays insert ink cartridge and stops it.
    Help me please[/QUOTE] post pic of message on the screen
    when you say 'ink' you mean dry black powder (toner) right?
    is the toner spilled out on the inside of the machine?
    are you using Canon OEM toner or compat?
    • justo66
      • Apr 2019
      • 6
      Re: canon ir 2870
      I mean toner
      I am using compatible toner
      • justo66
        • Apr 2019
        • 6
        Re: canon ir 2870
        It started by display e00024 0001, I solved the problem, it print some copy and after begind to display that message
          Re: canon ir 2870
          didn't answer the other questions...
          I'm done!
          • Brian8506
            • 1666
            Re: canon ir 2870
            Is the toner bottle in the machine empty? If not you need to replace the hopper. Common problem
            • justo66
              • Apr 2019
              • 6
              Re: canon ir 2870
              Thank you Brian8506
              There is no toner in the bottle, but there full toner in the developping assembly.
              I don't know why it display that message
              One more thank you for helping me
              • justo66
                • Apr 2019
                • 6
                Re: canon ir 2870
                Thanks you
                There toner bottle is empty, but there is full toner inside the developping assembly, I don't why it display that message.
                • Brian8506
                  • 1666
                  Re: canon ir 2870
                  Did you try putting a new toner bottle in? The machine will go into add toner when the developer calls for toner and the hopper is empty. This is basic copiers 101.
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 5016
                    Re: canon ir 2870
                    This message is caused by an empty toner container.
                    • justo66
                      • Apr 2019
                      • 6
                      Re: canon ir 2870
                      Hi
                      when I put the full toner container , it full the developping assembly with toner and to work, and begin to make big noiuse when print
