IR 6055i won't load up
  • darkocg88
    • Jan 2018
    • 63
    Upon turning on, loading bar reaches half, then machine resets.
    Machine is Canon iR 6055i.
    Any ideas? Thanks.
    Sent from my Moto E (4) Plus using Tapatalk
    Re: IR 6055i won't load up
    Originally posted by darkocg88
    Upon turning on, loading bar reaches half, then machine resets. Machine is Canon iR 6055i. Any ideas? Thanks.
    what have you tried?
    could be HDD - firmware - other component
    • darkocg88
      • Jan 2018
      • 63
      2 8 boot, still restarts. I think it's PCB1, just need second opinion.
      Can't do firmware update, restarts within 20 seconds max.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        Clean and reseat all contacts,memory.....
        Do you have fax board installed?
        What happen if you turn on copier with hdd unplugged?
        • dan7777
          • Dec 2012
          • 680
          Restart may be ram. I was thinking HD until you said that. Seems like you could boot to HD, format and reload software but I have had computers (was ram) and one Canon that did that but it would start and run a while before rebooting and they traded it in because they let the maintenance contract expire. Also main controller but not sure if that has two like some of the other ones. Glad it is not me.
          • Canuck
            Tech Specialist
            • 1713
            Reseat any RAM. Disconnect finisher,etc, open all doors, drawers, etc then try to reboot after unplugging from wall and plugging back in. Can you run a Main-con or Boot Check?
