IR-Adv C7065 - chasing my tail
  • icesoft
    • Sep 2011
    • 8
    [Error Code] IR-Adv C7065 - chasing my tail
    Been working on this iR ADV C7065 off and on as I find time. Original failure was E602-0513, reboot of machine returned E748-2024.
    Found retention screw missing from Main Controller 2 PCB, so I swapped Main Controller 2 PCB (thinking it had rattled out of the slot while powered up, damaging it), received same E748-2024. Attempted reformatting/replacing HDD.
    Reformatting/ALL gives me:
    Formatting HDD(ALL) ...Error
    All downloaded file is deleted.
    Now I get a E602-4000 after reformatting hard drive with either USB firmware or SST.
    Attempting the HDD Initialization with the SST gives the same error on copier, SST reports:
    Have tested original hard drive and replacement hard drive with Seagate SeaTools (to verify hard drives were actually good)
    Is it possible that I have a bad Main Controller 1 PCB?
  • guitar9199
    • Sep 2016
    • 1100
    Re: IR-Adv C7065 - chasing my tail
    If you've replaced the HDD, and swapped out MCON 2, that would be my next guess.
    It's been a while, so I can't remember if you can swap Controller 2 between machines or not. It may need to be a new/refurbished board. I'd check the GRID on eSupport.
    • mrfixit7
      • Jul 2018
      • 40
      very possible you have a bad pcb board
      • mrfixit7
        • Jul 2018
        • 40
        when replacing main control board its important to keep 3 small support boards located on original control board, they contain start up info and are slaved to machine for life of machine. the 732code is a mismatch of board, just a generic code for something is not correct.
