digitaltech006 12-13-2008 02:43 AM cant print
installed new harddrive on IR4570 and firmaware file. it goes into ready. input new ip address for printing. downloaded printer driver but it will not print. check computer and copier every thing looks fine. i can ping printer and open WEB Page, but it wont print from computer. installed PCL5e driver RAW and LPR. Can Any one help me find other drivers or does it need a special port instead of Standered TCP/IP.
Are you able to ping the copier from the network side...and are you able to ping the network from the copier?
If you can't ping in either direction and you're using the correct I.P address then you need to look at the connection to the server.
The Nic(Network Interface Card) on that model is built into the Main Controller pcb and I've had quite a few of them fail...which means a new Main Controller pcb.
I've found that the Rj45 socket doesn't seem to hold the cable in place particularly well.
